Short Block 383 Stroker
I need to replace the block from my 2003 C5 Z (along with all of the rotating assembly).
Since I'm going to be replacing the lower end anyway, I've decided to replace it with a stroker 383. My shop wants to buy a crated one in order to save time and get things going (the season is already slipping past with me on the sidelines...). The engine was originally modified by Lingenfelter to a 480hp. It has a really nice set of heads which will be reused after machining them to return them to line new condition. The cam seems to have caused not one, not two, but three catastrophic engine failures (valve meets piston = bad things). That cam will NOT be returning to the engine!
If you would be so kind, I would like to hear about your experiences with the different providers of pre built short block strokers - both good (and maybe even more importantly), and bad.
Thanks for your help!
Jeff
Jeff
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
When I bought my motor (forged LS3 based shortblock, 377 CID) it was down to LPE, Scoggin Dickey, or Texas-Speed. I went with Texas-Speed because research indicated they were built by the same company as Scoggin Dickey, but Texas-Speed didn't want a core charge for the new motor. That saved me $1K on the spot. Both were about $700 cheaper than LPE plus core which was only on the list really because they were local, but wait times really killed that.
Motor has held up FINE to some serious power.
Jeff
Jeff
I could have reused my heads, but when I price shopped long blocks and factored in getting heads done, cam, labor.....done right, it was a no brainier. Ask how much for labor and parts and then add that to the short block price.... then price a long block from sdpc, my forged 383, with ported heads was not much more, when I factored all that in.
Good luck
Good luck
