Odd Front, Pass side tire wear with good alignment
Alright, so I'm stumped. I spent most of the winter doing some work on my 2004 z06. I have stock z06 rims, suspension, ride height, everything. I bought it approx 2.5 years ago with the P.O. admitting he was backed into but as I've worked on it, I think it was a more significant impact.
I replaced the steering rack (leaking at the magneto wire) and new motor mounts. I was going to replace the bushings but after I got the new bushings in, I went to reassemble everything and I noticed that the driver's side lower control arm was bent and the upper passenger's side control arm was bent. I assumed I had bent them when I was removing the old rubber bushings. I went ahead and bought used pairs for both sides. So the car has all new to me used control arms on the front. I got everything aligned and everything seemed fine until I was checking a popping/clunk noise coming from the front end at low speed turns. I was checking all the bolts and noticed a rub mark on the passenger lower control arm. I remounted the wheel and checked and with the car in the air, it rubs on the upper control arm. I also have really bad camber wear on just that tire. I had an alignment done (approx -1.3 degrees camber with 0 toe and approx 8 degrees castor) immediately after the steering rack repair and then drove approx 800 miles and then noticed the alignment had slipped on the drivers side and had the dealer redo the alignment. I have 1 mile on a new alignment approx -1.8 degrees camber with 0 toe and approx 8 degrees castor.
I don't know what would cause this. Could it be frame damage? Could something with the new rack cause this? As far as I can tell, the new control arms are good but is there a way to check them without buying more?
Thanks in advance.
Thanks in advance.
Well, I had -2 degrees up front for 14k miles on these same tires before I replaced the steering rack and didn't have this kind of wear. I should also say I track the car and even with -2 degrees, they wore evenly. This is unique to just the front passenger wheel and is new.
Either way, I'm more focused on trying to figure out why the rim is rubbing on the control arms with a good alignment.
If you're referring to the question about tires, I said it's the same tires I've had on there. Plus, I'd expect the wear to be the same on both sides if it was camber wear but it's significantly worse on just that tire.
Otherwise, it's time to check suspension mounting point positioning side to side to see if you have frame damage. Given that the control arms were bent, frame damage is sadly likely.
I don't understand your post.
800 miles with a slipped front alignment and 1 mile after fixing the slipped front alignment and you're asking why a front tire is wearing funny?
Can you at least post the alignment printout? People say they have a good alignment all the time but the data shows otherwise.
I would check the rack and the steering arms/spindles for something off in the steering components.
If you go to full lock one way, the rim rubs on the control arm, correct? So, how much clearance is there at the corresponding spot on the other side at full lock the other way? If there is clearance, first step is to check for a mis-match in steering tie rod lengths side to side, or a mis-positioned rack. Both would allow too much lock in one direction.
This car gets tracked which is why it's an aggressive alignment so I understand there is going to be more camber wear on the street but what I'm seeing is extremely excessive considering it's just one wheel.
St. Jude Donor '15
Post a picture of the tire in question. Never saw a slipped eccentric give a more positive camber.
Also the rim should touch the upper control arm. After all you lifted the car and the suspension is at full travel. As far as the lower goes, something is allowing further turning travel than normal.
