C5 corvette Half shaft length needed, rebuild info
I have a 2008 C6 corvette with C5 half shaft axles installed,due to C5 being a stronger shaft joint, the problem i noticed is my C5 half shaft outer rubber boots rub on my rear pfdat coil shocks, pfdat told me that the coil shocks woud not rub ifi had C6 half shafts, i found out C6 boots smaller diameter. is there any one using C5 axles on there C6 corvette and using pfdat feather light drag coil shocks. thank you
