Help please: bolt size for PFADT transmission mount?
I bought a used Pfadt transmission mount, but it didn't come 'complete'. It arrived with the pads and swivel bracket attached.
There was no other hardware included. The entire assembly looks like this:
Several OEM photos show that there should be 4 shims and a couple (blue) 8mm Allen head bolts, like this:
I'm pretty sure I can find the (blue) 8mm Allen bolts and the shims (or something suitable) at Lowe's. But I don't know what size Allen bolts to buy. Can some please tell me their length and pitch?
Thanks very much!
Thanks very much!
On my pfadt diff mount, it had 12 pt arp bolts for those fasteners. I don't know the thread but they screw into the diff so you could just take the factory mount bolts into ace and match it up with something. You could calculate the length from this picture.
Those bolts are sort of a pain to get in a normal bolt will make it much easier then allen head as long as your sockets fit down into the mount, as my sockets are much shorter then my allen sockets and the verticle room available is pretty tight there even if you start jacking up the trans/diff to make space there isn't tons of room for sockets and a torque wrench.
https://www.google.com/search?q=pfad...%3B1824%3B1368
Oh yeah those are 1mm shims but they are honestly sort of arbitrarily inserted. If you use more it will be tighter less it will be a little looser. I had like 9 i think and used 4, 2 per side. My buddy used 6, 3 per side.You could just buy 2 or 3 mm worth of washers and put them in ahead of time imo, would be fine.
Thanks! All that info will really help.
Thank you!
So i guess i agree overshimming it plants the rear end more firmly at the cost of nvh, undershimming it reduces nvh to a degree at the cost of rear end twist.
You need to consider which way you want to go with it for sure and what you can put up with.
