HELP - My C5 wont start / crank :(
Old 06-15-2015, 09:24 AM
Baddabing
Baddabing's Avatar
Default HELP - My C5 wont start / crank :(
Can somebody give some advice ?
Started with my ignition switch was bad (bad connections), so I replaced it.
After that the car would not start anymore.
Tried to put the old ignition switch in again, still wont start.
Battery is ok, 12.62 volt.
No codes.
Fuse 14, 50, 52 OK
Replaced the starter (that was my first guess).
Replaced the Theft Deterrent Relay.
VATS is deleted (resistor) - also tried to disable it in HP tuners.
It's clicks, but wont crank.
I have tried the 3 x 10min re-learn, but the security light does not blink.
When I JUMP the Theft Deterrent Relay RED & PURPLE wire with the IGNITION KEY in the ON position, it's starts and runs.
There is no volt on the yellow wire, on the Theft Deterrent Relay, with the IGNITION KEY in the ON position.
Old 06-15-2015, 09:51 AM
Baddabing
Baddabing's Avatar
Originally Posted by 8VETTE7
Sorry for the incorrect info in your other post about the voltage being at the yellow wire in the ON position of the ignition switch. Voltage should ONLY be on the yellow wire in the START position.
Did you verify fuse #14 is good?
You can check the voltage at fuse #14 with the key in the START position. BOTH should be battery voltage as well at the yellow wire in the Start position.
Fuse 14 - OK
Took fuse 14 out, and checked for Voltage, in start position.
Also checked yellow wire on TDR, in start position.
NO VOLTAGE.
Old 06-15-2015, 10:45 AM
Baddabing
Baddabing's Avatar
I'm unclear on your response. Are you saying NO voltage at fuse 14 with key in START?
NO voltage at fuse 14 with key in START.
Old 06-15-2015, 11:22 AM
Baddabing
Baddabing's Avatar
Look at the wiring diagram left side. Is fuse 50 good?
Nothing but wire between the ignition switch and fuse 14. Seems like it can only be a problem with the switch itself or the connector at the switch if fuse 50 is OK.
Fuse 14, 50, 52 all OK
The ignition switch is new.
Tried the old one again (had a loose connection - but worked).
The car can't crank, with the new or the old ignition switch.
Maybe it's the wire to the connector ? What color, is the wire, going from the switch to fuse 14 ?
Old 06-15-2015, 04:42 PM
Baddabing
Baddabing's Avatar
According to the wiring diagram it is Yellow.........
You can check the yellow wire at the ignition switch to verify the switch is good.
Checked the Yellow wire at the ignition switch - NO VOLTAGE.
So, it can only be a bad 'brand new' ignition switch ??
Old 06-16-2015, 09:39 AM
Baddabing
Baddabing's Avatar
Sooo - problem solved.
Took the old ignition switch and cleaned up the contacts.
Installed it, and the car started right up.
Used Bill's guide:
https://www.corvetteforum.com/forums...ch-repair.html
So the new china crab ignition switch was the problem
Now i'm ready for the Corvette meet, here in Denmark
Old 06-16-2015, 02:35 PM
73Corvette
73Corvette's Avatar
Old 06-16-2015, 03:28 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Can you take that NEW switch apart and find the smoking gun????
Bill
Old 06-16-2015, 03:34 PM
Baddabing
Baddabing's Avatar
Bill
Took the new switch apart.
Connections was bad, loose spring tension and overall quality was bad.
Cleaned up the contacts., and gave the springs some tension.
I think it will work now, but have not tested it.
Old 06-16-2015, 05:13 PM
RXPX
RXPX's Avatar
Thanks for posting the solution to your issue.
Bill
Thanks to the two of you for taking time to help, I'm sure it's appreciated by very many, including myself.
Glad to see you got the car up and running! I'm waiting for the storm to pass us by here where I'm located so I can also rebuild my ignition switch.
Old 07-10-2015, 03:56 PM
DinkyDonut
DinkyDonut's Avatar
Used Bill's guide:
I almost glossed over that last part; det er da godt at se, at man stadig kan finde en C5 derhjemme! Mvh. en der voksede op lidt udenfor Nastved.
Just wanted to chime in and say thanks to Bill for that post on the ignition switch repair. I had to track down some electrical gremlins in the wife's C5, and that switch proved to be part of the problem.
To HELP - My C5 wont start / crank :(
Quick Reply: HELP - My C5 wont start / crank :(
