AC blows hot on drivers side
Old 06-22-2015, 01:26 PM
bad455ta
bad455ta's Avatar
Default AC blows hot on drivers side
I've done the searches and I pulled the number 27 fuse and still have a problem. This happen to me about 2 weeks ago pulled the number 27 fuse and then everything worked just fine after I reconnected it. But this time it's not working. Any suggestions?
Old 06-22-2015, 04:03 PM
mrlmd
mrlmd's Avatar
One of the possibilities and maybe the easiest to resolve is that you might be low on Freon.
Old 06-22-2015, 11:14 PM
BigGun
BigGun's Avatar
Unfortunately that "fix" is usually temporary and when it no longer works it is time to replace the actuator. Sometimes resetting the code will buy you a little more time.
Old 06-23-2015, 07:27 AM
dadaroo
dadaroo's Avatar
Old 06-23-2015, 07:36 AM
TOPCATHR
TOPCATHR's Avatar
very common problem. try recharging system to correct level of Freon.
Old 06-23-2015, 08:32 AM
vettenuts
vettenuts's Avatar
Not Vette related, but I am dealing with the exact same issue on my daughter's Envoy. I moved the actuator by hand and unplugged it for now. I suspect the control head since I did see the actuator try to calibrate and return to the hot position. If not, than the actuator will need to be replaced.
Old 06-23-2015, 02:07 PM
bad455ta
bad455ta's Avatar
Guess I was pulling the wrong fuse
Old 06-28-2015, 08:29 PM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
just replaced both actuators in my 99 for the same issue....it wasn't as daunting a task as I imagined but it wasn't any fun either....ordered aftermarket parts and did it for waaaaaaaay less than I was expecting...pretty much under $100
Old 06-28-2015, 08:42 PM
mrlmd
mrlmd's Avatar
Did you ever check the freon level? That's the most common cause of this problem.
Old 06-29-2015, 09:42 AM
bad455ta
bad455ta's Avatar
Turns out, for some reason, every time my battery gets disconnected, the driver actuator needs to be reset via the fuse method.
Old 06-29-2015, 07:18 PM
Chicago1
Chicago1's Avatar
https://www.corvetteforum.com/forums...1a147a9f73d5e8
Originally Posted by dadaroo
a bad actuator will throw a code..
To AC blows hot on drivers side
Quick Reply: AC blows hot on drivers side
