Will stock manifold gaskets work with obx headers?
I see no reason they wouldn't, unless they have some sort of defective flange. You could check them with a straight-edge. There's only two different flange designs, round port and "D" port (LS7), and the bolt pattern is the same for all, including the LS7.
Are OBX offshore?
Are OBX offshore?
Stock exhaust manifold gaskets are the actual gasket of choice in any header application. Run them. You'll be happy you did.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
So everyone knows...no, they don't work. The 243 head has a shorter rectangular type circle exhaust port, so the round headers will not accept that, unless you want gasket blocking airflow. Back when I did my headers 9 years ago, I used 2000 camaro gaskets. They were circular. Ls3/7/9 are D shaped.
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
The superseded part number for the LS1/2/6 heads are all round port gaskets. They will work best in any header application.
Heck, I use them on my LSX-LS7 heads.
