My first Vette
My first Vette
Hi everyone, I'm enjoying all the great threads, articles, and info! I recently became owner of a 98 convertible Corvette, my very first one. It has 66,200 miles and in great shape, There is however one problem I am experiencing. When the car is idling all the lights both interior and exterior flickers every 10-20 seconds, the strange thing is, if I accelerate the engine to higher rpm's the flickering stops and all lights illuminate as expected. Would this be the symptoms of a faulty alternator or something else that may be the culprit? Thank you for your response in resolving this issue!
Hey, I just had to post back up to tell you that I found out what the problem was. After doing some more investigation looking for corrosion and anything that looked abnormal. I found the battery terminals were loose, that I could even move them by hand. Tightened them up and I'm good to go!! All is well! Maybe this would help others who may encounter this problem!
Welcome to the forum. Man you ask for help and answer your own question, you trying to get banned?
Glad you got it sorted out, seems like battery/low voltage/ground issues are the main source of problems with the C5. Great car however.
My first Vette
Originally Posted by Big Kidd
I totally agree!! Make sure you keep a good battery in your vette, low battery voltage will cause all kinds of weird issues in these cars.
Pro Mechanic
Welcome to the asylum!
