I need a spare tire
Is this answer good enough?: https://www.corvetteforum.com/forums...-in-a-z06.html
Thans for the reply Dork. That helps a little. I think.
Thoughts at present,
I was going to build a box, big enough to accommodate the rear tire. Cover it inside and out with the same kind/color material as the rear area carpet. Use the holes already there that hold the carpet panel to hold the box. Should work if done properly. Taper the front a bit to serve as storage for a board, jack...
All-in-all try to make it function for my need and at the same time NOT look like crap.
Just my thoughts at the moment. Subject to change.
Keep in mind, two things....
1) the limited slip differential in the rear axle, will NOT be happy if the rear tires are different diameters. AND the difference doesn't have to be a lot, to cause the clutches in the diff to generate a lot of heat.....
2) the active handling/traction system wants to see approximately 1" difference in the ODs of the front and rear tires. It functions on seeing wheel speeds that are pre-programmed into the car's computer. If these speeds are outside of the "normal" window, the active handling system most likely will engage.
It would be difficult to keep the diff and traction control system happy at the same time
Excellent points. That's why I'm here, now so you guys can weigh in on things.
TC can be turned off. Most of that doesn't seem to be an issue on other cars I see running around for days on a donut. But, more thought...
Thanks much for you reply.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have a ZO6 and it came with NON RUNFLAT TIRES and NO TPS Monitors. I installed TPS monitors.
However ALL ZO6s come with a tire pump and a tire patch/plug kit. When my other C5 and C6 cars wear out the RUN FLATS, I always switch to Non RUNFLATS and just purchase a dependable pump and a good plug kit.
Unless you have a catastrophic tire blow out, a good set of TPS and a plug patch kit will handle most leaks.
Other than that,, AAA and a flat bed will get ya back on the road..
People purchase a F Body mini spare to be able to get to a repair station. YEP,,, You have to be careful with the limited slip clutches and different size rear tires.
My wife had a complete rear tire blow out on my ZO6 at highway speeds and the wife stated, "If it weren't for the tire pressure sensors, she never would have knows it was flat." Didn't effect the handling all that much.
Looks like it would work but with some of the other comments I have a question.
Have you ever actually driven with your spare?
If yes, how far?
Front or rear?
Any issues with TC or the limited slip?
Any issues at all?
I disagree with the topic of this conversation.
You do not need a spare tire.
There were over 225,000 C5 Corvettes producted, zero of which had a spare tire from the factory. Add in the C6 Corvettes, which also do not have a spare, and there are nearly half a million spare-less Corvettes on the road.
You do not need a spare.
You may want a spare, and that's fine. Lots of people want things that are unnecessary. In fact, for most people, a Corvette is an unnecessary 'want' and not a 'need.'
I do not run a spare; I pay a couple bucks a month to the insurance company for 24/7 roadside assistance, and they'll pay for a flatbed. I also have a plug kit and compressor in the car, but I honestly can't imagine ever using them. So far I haven't had to use either one.
So, anyways. You don't need a spare.
I just bought a 2004 C-5. I really like the car.
I will carry a tire plugging kit, a tiny air compressor, a Triple A card and a cell phone for really damaged tires.
FWIW - I do have a spare tire but it is wrapped around my waist and mostly useless.
I have done 2 cross country trips from California to Bowling Green, numerous runs to Portland, Phoenix and Las Vegas. Only one trip to Phoenix did I have a tire issue. I picked up a piece of metal in the center of the tread while in Phoenix. Took it to the local Discount tire and had them patch it.
To get it there I used my portable compressor to fill up the tire before driving the 5 miles to the shop.
My C5 has over 132k mile of which I put 110k on it. My C6 has 32k with me putting on about 13k. I have a compressor and plug kit in both cars at all times. I add a blanket for road trips.
BTW, the C5 has Hankooks on it right now. The tires that got the flat were Michelins with about 5k on them when I got the flat. The C6 still has the factory Goodyears but will be replaced within the next 5k to 8k withnthe current Hankooks.
Gary
Gary
Between semis and my vehicle I drive over 100,000 miles a year. I have had 1 flat in the last 15 years while on the road. Maybe 3 that were flat when I was ready to drive. All on semis. I am not worried about flats. The one on the road a handle from a bottle jack was rolling around inside the tire. Made a nice clean hole but too big o repair.
