DeWitt's Radiator Installation Results
Old 06-29-2015, 09:55 AM
TwinTurboZ51
TwinTurboZ51's Avatar
Default DeWitt's Radiator Installation Results
deleted
Old 06-29-2015, 03:01 PM
tlove32
tlove32's Avatar
You should change your fan settings. I have a Dewitts and NEVER see over 205 degrees.....even in 100+degree weather. My temps around town are in the 190 range...and 175'ish on the freeway.
Old 06-29-2015, 03:21 PM
rodsvet
rodsvet's Avatar
I'm supercharged with a 3200 stall and a stock radiator with the trans cooler going thru the radiator. At 100 degree days, I rarely see 195. I would have thought your temps would be lower. Reset those fans! Rod PS, I am running a external trans cooler with fan.
Old 06-29-2015, 03:24 PM
alxltd1
alxltd1's Avatar
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Quality product indeed. Question though: So what is the sweet spot, for lack of a better term, for the LS1 engine in terms of engine temperature? Understanding obviously that excessive heat is bad, I would venture to say that there is a point also of being to cool as well. In their testing GM I am sure had a range in mind that the cooling system was optimized to achieve and provide optimum performance also. While mods may alter the baseline of the LS1 I am just wondering how that affects the optimum operating temperature goal.
Old 06-29-2015, 04:08 PM
TwinTurboZ51
ET has posted previously his knowledge of optimal temps. I believe it was 205-210 degrees but not 100% positive.
Since my temps dropped from 247 to 205 now I am very pleased.
My fans wont ever kick on unless I get a hot day and hit 226.
I may purchase a CoolIt switch to start the fans when needed. I dont want to change my tune at this time.
Old 06-29-2015, 04:24 PM
dbgoodwin
dbgoodwin's Avatar
Your temps are now ideal, glad you were happy with the product. Many people seem to get worried at seeing 200+ but that's where the engine is designed to be, so by forcing it to run at 175 you're making it run at a less than ideal temp.
Old 06-29-2015, 05:39 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Originally Posted by TwinTurboZ51
Nice! Dewitts makes an excellent product.
Btw, I noticed your stock fan shroud is different than mine, so I did a little sleuthing. It turns out your '97 is the only year with that particular design. It has separate fan mounting brackets for each of the two fans and the main shroud also has two horizontal "slots" (or openings) where is looks like flaps (missing in your picture?) would open up at speed. The fan motors and blades themselves are the same part numbers as the rest of the C5s through '04.
This would be good to know if you ever have to replace the shroud for any reason. AAMOF, the later design assembly could very likely be retro-fitted to a '97 and for a whole lot less money. The later units do not have separate fan mounting brackets; they are incorporated into the shroud itself.
You can see this in this parts drawing:
Here's a pic of the '98 thru '04 I found and you can see the difference:
Old 06-29-2015, 09:20 PM
racebum
racebum's Avatar
for what they charge i would hope so...
and i don't even mean that in a bad way. quality is worth paying for. i'm just surprised that no one over the years has started turning out a similar quality product in their own shop for as much margin as these things have
Old 06-29-2015, 09:23 PM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
buy the SPAL fans....you will really get some air moving....
Old 06-30-2015, 09:46 AM
alxltd1
alxltd1's Avatar
Thanks. I did a little searching and Evil Twin addressed this in 2005 with this " ( 190/200 coolant... and 200/210 oil )". So that may be the range I will shoot for.
Old 06-30-2015, 10:58 AM
TwinTurboZ51
Thanks for the information LonestarFRC. That is good information on the shroud/fans.
I drove the car to work today which is 30 miles and 90% highway. The car never got over 194 on the highway.
I dont see the need to spend 400 on SPAL fans at this time.
Old 06-30-2015, 11:50 AM
0Tom@Dewitt
Former Vendor
Tom@Dewitt's Avatar
Assume 2010 Corvette model
C&R $1799
http://www.summitracing.com/int/part...model/corvette
Be-cool $960
LG Motorsports C5 $995.95
https://www.lgmotorsports.com/corvet...diator-c5.html
DeWitts Base model C5 with no coolers $545
DeWitts full option with both EOC and TOC $695
http://www.dewitts.com/collections/c...ator-automatic
I think are pricing is just fine when you look at the brand name leaders.
Old 06-30-2015, 12:02 PM
junk c5
junk c5's Avatar
C&R $1799
Be-cool $960
What's your critique on the Big End Performance line ?
http://www.indyperformanceproducts.net/bigendpera.html
Old 06-30-2015, 12:07 PM
0Tom@Dewitt
Former Vendor
Tom@Dewitt's Avatar
I have no experience with them but whenever I see a double row, 1.0" core aluminum radiator selling for under $500 it usually means it was made in china or other overseas location where material are subsidized by the government and labor is cheap. These are typically a generic universal and not a direct fit. Not all imports are bad, it's just a crap shoot.
Old 06-30-2015, 12:13 PM
junk c5
junk c5's Avatar
Definitely not a direct fit and requires some fabrication and/or different radiator hoses. Most of my builds require fabrication so I've had good luck with them. I was just curious what your opinion was on them since they're in your wheelhouse.
Old 06-30-2015, 04:26 PM
racebum
racebum's Avatar
C&R $1799
Be-cool $960
of course you do, you're who's making the profit
and i get that on a low volume item like specialty radiators. i'm just surprised that we haven't seen any private small shop competition
when you look at high volume cars like the turbo hondas / bmw which can all use the same radiator. koyo is producing a similar sized radiator for about $300 with shop cost around $170-200. these things are made in japan with some very high quality aluminum.
http://www.redline360.com/koyo-radia...q1-BoCDBjw_wcB
market is what the market is, i'd just be thankful you haven't had anyone make an end run on pricing
and i totally do acknowledge that you have a similar quality product to becool for almost half the price. i mean, i'd buy one if i got back into racing again
Old 06-30-2015, 07:32 PM
joe's98
joe's98's Avatar
St. Jude Donor '15, '17
I put a DeWitt's in my '98 two weeks ago with similar results. I had my car tuned which included changing the fan settings. It was due for a tune anyway. Great product. I had a tough time paying the price, but I have no buyers remorse. The quality and fit were terrific.
To DeWitt's Radiator Installation Results
Old 07-10-2015, 09:16 PM
jrprich
jrprich's Avatar
Having an overheating issue on my 99 on days over 90. Can hit the 240+ when in traffic.
What would you suggest changing first? the fans to a SPAL setup or the original radiator to a DeWitt.
I can't afford to do both at once.
My stock fans have already been reset to come on earlier than normal due to a Chuck Cow tune.
Thanks in advance,
Jim
Old 07-10-2015, 10:29 PM
73Corvette
73Corvette's Avatar
The 160 degree thermostat will help in those HOT places during the summer... ET would run one during the summer months and then switch back to the 180 in the winter months.
Just put a 160 in our 04 and it's running right at 194...
Old 08-07-2018, 12:00 PM
holley505
holley505's Avatar
So dewitts with the stock C5 seems to be an improvement. Being I have a M6 car I dont need the Dewitts with all the coolers?
Quick Reply: DeWitt's Radiator Installation Results
