Air pump and EGR
Air pump and EGR
While getting info on another subject, I was informed that the C5 doesnt have EGR, and apparently has an air pump for emissions. I think I figured out where the air pump is supposed to be, but not sure what it goes into if not EGR. And what is this if not EGR?
the hoses are still there-that was the hoses we found the other day. I just ordered a air pump for it, so that will be fixed. Has to pass emissions inspection here in NC
Did you just order the pump? I ask that because there is a vacuum control solenoid interface also.
Received 1,261 Likes
or you could just remove everything else and have the corresponding codes removed with hptuners so you can pass your emissions test... the air pump is dead weight in my opinion
https://www.dropbox.com/s/byry3ulsw4...ement.pdf?dl=0
I can post more AIR info from the service manual if you need it to hook everything up.
