Water Leak - Passenger side
I have a water leak on the passenger side of my 99 FRC. I had the same problem a couple of years ago - a friend unclogged the drain holes near the cowl - no further problem.
My question - where exactly are they located? How do I reach them to unclogged them? The passenger side mat is damp which is why I first noticed things. Could it also be from the a/c? I have run it quite abit with the heat spell we have been having.
As always - any help is appreciated - thank you in advance
check the AC drain hose....common that they clog or possibly come loose under there
if that checks out you can pull the wheel, then the liner and you will see the udders
