Torque Specs
Clutch Replacement/Torque Tube Rebuild
Is there a resource available that lists various torque specs for all of the components, except for the shop manuals?
I intend to purchase the manuals, but my car needs to go back together this weekend (clutch replacement). Using the correct torque specs would be preferred, of course.
If I ask here, would there be anyone willing to list the torque specs for the components I list?
EDIT: Nevermind
http://temp.corvetteforum.net/c5/cgh1//c5torque.pdf
EDIT: Nevermind
Have any of you fellas been reusing the Rear Crossmember Mounting Nuts (21mm)?
Anyone know where I can find them, or can I look for a specific type of 21mm nut at a hardware store as a replacement?
Same question for the flywheel bolts...
I've reused them many times and most shops do also.
I will reuse the Rear Crossmember Nuts
One of the OEM flywheel bolts is slightly rounded. Nervous about re-using that one. I'll take another look when I get home.
Thanks guys.
Thanks guys.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I tried the link and it didn't work for me. Here is a PDF version of the Torque specs:
Found a local shop with ARP flywheel bolts. Picking those up tonight.
Also going to have another shop press the new bearings onto the torque tube for me. I found instructions that were pulled from the service manual, but they were for the automatic. Anyone have that on hand for a manual trans they could share?
