drive belt
drive belt
I have had a 2000 C-5 coupe with an LS-1 motor...Over the last 4 months my main belt has came off when it has been damp or after washing car...(4) times....It happens when I run it fast through the gears to 100 plus MPH....Perplexed in the Ozarks....:*****
Received 1,261 Likes
check the tensioner and pulley alignment... while you're there also check the balancer and make sure it isn't separating and causing the belt to walk off
