200 amp alternator?
200 amp alternator?
Hi folks;
I have located a 200 amp alternator for my 98 C5 and was wondering what, if anything needs to be changed besides the size of the charge wire to make this work?
Is there anything else that needs to be upgraded?
Are there any problems that this could cause in the electrical system of the car?
I want to get it right the first time.
Any suggestions would be greatly appreciated.
You will likely get the charge fault code on the DIC. Also the alternator may not start charging because the ECU sends the signal to the alternator to start exciting the field. Some cars have this issue, some don't. There are ways around some of this stuff. I'd wait and see if it acts up before you worry too much. Just add a 8 ga charge wire with a 10-12 ga fusible link section from the alternator to the battery. You should be fine.
But, the PCM has no active turn-on or voltage control over the alternator. Any claims that it does are false.
Thanks for the replies....
Thanks much for the reply. Can you explain why this system fault shows and why it needs to be fixed via tuning? Is there any other way to fix this?
The easiest way to fix it is to purchase an alternator from DC Power. Plug and play with no codes and plenty of juice.
The stock alternator has a soft turn-on regulator. You can watch how slowly the voltage increases when the engine starts. So, I suspect the message is caused by some aftermarket units that do not have a soft-start and basically jump to a high duty cycle until the voltage rises and the duty cycle drops again. The PCM is seeing the duty cycle go too high which triggers the charge fault message in the DIC.
As for the tuning, you can turn-off the L and/or F terminal monitoring in the OS settings. If I had access to an alternator that didn't work correctly then I'd try disabling each one to know which feedback causes the warning. I'd also scope the differences in timing on the L and F circuits to see what's going on.
Fundamentally, the Valeo has F and L terminals that do the same function as the same terminals on CS130, CS144 and a bunch of other alternators. You could just hook an indicator light between ignition power and the L terminal and the Valeo would still work even without any connection to the PCM.
