C5 Wipers Won't Park
Ahoy Vet Lovers, my lovely C5 Ragtop's wipers stopped parking (17,000 easy mi). Don't like them parking in my line of sight. Diagnostic C5 Shop Manual testing indicates a new wiper switch. My questions are:
1. Is the "switch" itself a part of the wiper lever? If not with the lever, where is it?
2. Is the removal/install something relatively easy to do (given a full shop manual set)?
3. Where's a good, low-priced place for this part?
4. Have you ever done this replacement and would be willing to share?
Thanks, guys, stroke your Vette softly,
Tom, Naples, FL
Tom, Naples, FL
Review this and let me know if you need any more info. I can provide the FSM info for getting to the motor and controller there and anything else you need.
https://www.corvetteforum.com/forums...iper-arms.html
I cases where they do not Park correctly it seems it is always the board at the motor from what I have seen. My understanding the only thing the column switch does for Park is to just kill power and then the control board at the motor makes sure the motor Parks the wipers correctly. The fact that the wipers stop tells me the column switch is not the issue.
They don't specifically address "No Park" the FSM diagnostics from my review.
Mr. Sam
PS: Here is another Thread that supports my opinion, Post #2.
https://www.corvetteforum.com/forums...sue-again.html
Mr. Sam
Thanks, here' my reference
Mr. Sam
Mr. Sam
Back to my post, is this a big deal operation? What might it cost to have a dealer repair it? Where should I look for parts? Thanks, Tom.
Wow, my 2001 hardcopy only has 28 pages on the Wipers and Washers.
I have all the years on my laptop and may take a look at your year later just to see what it says.
I will repeat, there is no logic as to why an on/off switch would be the issue in my mind (even with resistors there).
That is supported by what I provided you.
However, if you want to replace the column switch you can get new from Gene at Cultrag.com (great discounts) or used from Marc at VetteNuts.com (great prices).
When you find out it is not the switch this link may help. He also defines your problem as being at the motor. Lots of pictures too. Junkman DIYs are always well done.
http://www.digitalcorvettes.com/foru...d.php?t=121213
If you do go for the switch this may help. It has guidance on access to the MF switch but will allow you access for the Wiper switch also.
Let us know what happens and if I can help with anything.
Mr.Sam
Mr.Sam
Thanks for your answer. I'll dig deeper. I have a lot of time and the interest to follow this to an end. My shop books say to "disconnect connector C219" at the start of the diagnostic. Where the H is this connector? Book says it has 6 cavities??? and it's location "Instrument panel harness to steering column harness, LH side of the instrument panel attached to the instrument panel lower beam." Wiper schematics show C219 just ahead of the switch.
Another thing, maybe unrelated but maybe not, yesterday my Vette's battery was dead! Could the wiper switch be closed and and discharging the car? I'm 1000 miles from home and my Vette is my only ride.
Thanks, Tom
Thanks, Tom
Yes there could be connection. I did pull up your diagnostics and saw that if there is a short in the column switch circuit it can cause your issue. That could drain the battery.
I am going to PM you with my contact numbers so we can deal the drain issue. I will be at my cell for a few hours until I get home.
Charge the battery WITHOUT the battery being fully connected to the car. Will explain why later.
If not that it could be a light left on or a stuck seat switch causing a motor to try and run. There are thermal circuit breakers that open and close in this situation until the battery is drained.
......... My shop books say to "disconnect connector C219" at the start of the diagnostic. Where the H is this connector? Book says it has 6 cavities??? and it's location "Instrument panel harness to steering column harness, LH side of the instrument panel attached to the instrument panel lower beam." Wiper schematics show C219 just ahead of the switch.
Thanks, Tom
Thanks, Tom
All that information is in your FSM.
Is it this one? The one that is actually attached to the wiper switch that you're working on?
Thanks buddy, I have a short cut on the diagnostics if the switch is the issue. If he looks at current draw on Fuse 10 in the I/P fuse box it should show a current draw. Waiting on a call. I have several ideas that will get him home regardless of the issue.
If that is the problem pulling Fuse 10 in the I/P fuse box will stop the draw. If it rains he can just install for driving.
Interesting issue.
As always, Mr. Sam
Interesting issue.
As always, Mr. Sam
Interesting issue.
As always, Mr. Sam
Interesting issue.
As always, Mr. Sam
Well I didn't read all the links, but I had my wipers go crazy . Wouldn't park, came on at random times etc. The "rubber Udders" got clogged leaving the wiper motor and its circuit board sitting underwater. I got lucky, I pulled mine out and opened it up. Dried it out and it and now it's fine. There is a thread some where on here on how to remove the motor. It's not a very hard job.
If you don't have a drain via fuse 10 then that switch should not be the problem with wipers not parking.
Replying/Up-dating
Perfecting the arcane GM diagnostics is no small matter. To do all testing means completely exposing the work area! Unless you are a Corvette mechanic, know that nothing is marked and most connectors are fastened to metal (think hard to disconnect and reconnect).
After study I found that I read "replace the wiper/washer switch" a lot more than any other cure. I bought a switch from Eckler's and waited a few days before it came.
I launched into full scale, bare it all, replacement approach….except I couldn't do the "bare it all" part. Everything's torx and, I discover torx, socket drives and long shafts. So I, unfortunately, decided to DIY-it in a partially open work site. With the I-panel partially removed in my only ride, I couldn't easily get the tools. So I worked around things. Picture this.
I, ahem…, slid a few switches off the steering column and removed the suspect wiper switch completely. I hooked up the new wiper switch, hand-held the switch and fired up the wipers…more of the same lazy wiper parking. So now I'm pondering whether or not I'm trying to milk a NC mouse here. After all, the wipers do wipe…they park just like like my ex-, anyway she wants.
Will try to call you at home in the PM this coming week to see if you, or anyone, have any ideas. Tom
Sorry, but I knew if you had no current flow at the fuse and they were not Parking then the switch/circuit short could not be it. All I did was just short cut the FSM diagnostics. If you had a current draw then you would have had to get under the dash.
Go back to Post 4 where I said what it most likely was. The control board in the wiper motor assembly. When you turn off the wipers it is what parks them. It uses stored voltage in a capacitor to power the wipers until they park.
If it were a switch/circuit short it would have had to be one that was not enough voltage to power the wipers but enough to tell the wiper control board NOT to Park the wipers.
If you start with new motor out of the box, it will come with install directions telling you how to index motor properly the first time.That will make it a 30 minute job, tops
Mr. Sam
Mr. Sam
My parts info only goes from 97-02 but it just shows the motor as an assembly. The GM and AC Delco P/N is 12363318. I would think it is the same for all years.
Let me know if you need any FSM info.
