another Traction/ Active handling light.
I have a 98 convertible and the Service vehicle soon -Traction/Active handling warning comes on.
This happened occasionally at first and would go out after the car sat then was restarted. Now it happens more often then always after a few miles.
I have changed the 2 horrible ground connectors to groups of 3 cables soldered to ring terminals and those on the ground post on both sides of the engine compartment with no better results.
Traction control remains working even when the warning says it is off. I can reset the DIC to stop flashing by pressing the reset but the orange light stays on.
Any suggestions where I should start looking for a solution.
Here are the codes I just got. ( if I start the car now it does not give the trac error for the moment)
TCS 6 Codes
1282 H
1285 H
1287 H
1288 H
1290 H
1292 H
Previously I cleared all the codes ( only 4) but these came back
TCS 6 Codes
1282 H
1285 H
1287 H
1288 H
1290 H
1292 H
You can check the output of the steering wheel position sensor with a volt meter or tech II if you have access. This may give you an idea if the the sensor is sending the correct data or if there is a problem with the ebcm. Bad news is that the sensor is just as had to find as the ebcm.
Thanks for all the suggestions, in looking for the ground cable near the ECBM module I decided to check the plug into the ECBM... the handle lock was pulled up so the connector was loose... I pushed the connector in and locked the handle and now no traction issue codes so far, I should have looked at that first but until this issue came up I didn't know where the ECBM was.
See above in BLUE.
Highly unlikely that all these different sensors failed all at once.
Could be some poor grounds. Here are some links that can help you identify grounds locations and what is grounded at each location to check and clean as needed:
http://forums.corvetteforum.com/c5-t...locations.html
http://forums.corvetteforum.com/c5-t...tion-long.html Post #1
I don't have a good feeling that grounds is going to be the all the causes but they are cheap to clean.
If I was a betting person I would say the EBCM is going away. All these sensors communicate to the EBCM. Not a good situation on the 97 - 2000 cars since the EBCM is not repairable and there are no new replacements available. Used is pretty much the only choice and they are NOT inexpensive.....
any chance of helping out with my code readings
1214C
2285H
2284H
0851H
0856H
2601H
Thank you
Ed
Be glad to help but please open a new thread so you don't hi-jack this one and also add the correct first character of the codes. Codes are 5 characters and always begin with an alpha character. Much easier for me to look them up when I have all 5 characters rather than just the numerics.
