Stainless Steel Headers Made In USA for Under $1000 Shipped @ Hinson Motorsports
Former Vendor
HINSON Motorsports is proud to offer the only ceramic coated stainless steel header built in the America under $1,000. The HINSON Motorsports C5 header systems are proudly built in the USA from stainless steel and then ceramic coated for lower under hood temperatures. Our ceramic coated stainless steel headers use mandrel bent 1 7/8" tubing and 3/8" flanges for a precision fit and finish.
Features
Stainless Steel Construction and High Temp Ceramic Coating
Easy installation for both wet and dry sump applications
1 7/8" Mandrel Bent Tubing for peak exhaust flow
3" Collectors
Lower under hood temperatures than non-ceramic coated headers
Slip fit collector for easy connection to a performance X-pipe
Ceramic Coated X-pipe for reduced center console temperatures
Direct fit application - No fabrication required.
Includes O2 Extensions ($50 value)
Includes
Ceramic Coated Stainless Steel Headers
Ceramic Coated Stainless Steel Header Extensions
Ceramic Coated Stainless Steel X-pipe
Stainless steel rear axle back connection pipes
O2 Sensor Wire Extensions (x2) $50 value
Clamps
Ceramic Coated X-Pipes for reduced interior temperatures
Installed prior to ceramic coating
In stock and currently being ceramic coated.
Former Vendor
Cool, we will look forward to working with you on them. Also add our shifter to your list. It will be out within a week or so.
We just wanted to share a few spy shots of what has been going on in our R&D department. We have been avidly working on developing the best short throw shifter for your C5 Corvette. Shown here is a picture from several weeks back, of one of the working prototypes we have been testing being pulled back out of the car for evaluation. Throughout the design process we have tested and made several changes to improve throw distance, gate width, preload centering tension, and handle designs. We have now started production of this ideal piece, and it will soon be available for purchase. If you are interested in being one of the first to get one of these new shifters, please email me and I will put you on an email list to contact you when it is available.
chris@hinsonmotorsports.com
Some of the unique features are, 4340 steel weighted threaded handles (included), billet anodized components, high grade oxide coated hardware (included), and the most unique feature of all, no centering springs to wear out. We have utilized this unique feature in other shifter designs we manufacture, and it works flawlessly to give you the perfect shift every time. With this design you get the confident feel of the "bump" out of one gear and "bump" into the next gear feel that we all look for in a short throw without all the trash and slop between gears. Our shifters also utilize heavy duty oversized stubs, to ensure long term trouble free operation. If you are or will be in the market for an aggressive short throw shifter for your C5, we have the option for you coming soon.
