Coolant temperature to high
I have cleaned my radiator 3 times since I have owned the car; it takes less than 1/2 hour. Remove the intake tract. Remove the cover that goes over the radiator and condenser. The radiator sits in a holder, slide it out of the holder and now you can get some space between the radiator and condenser. I have a small 3M electronics vacuum that I now use to clean the radiator. Piece of pie and no more hot car.
Edit- Actually, I think it's the condenser that sits in the holder. You move the condenser forward and that gives you room to access the radiator because it sits behind the condenser.
