torque specs on tranny drain plug
http://temp.corvetteforum.net/c5/cgh1//c5torque.pdf
I don't actually see an entry for the trans drain plug, but the diff drain and fill plugs get torqued to 26 ft*lb, and I bet that works fine for the trans as well.
Toque says to use 20 ft*lb: http://www.toquez06.com/tranny.html
I can't even remember what I torqued mine to...probably just "tight". Good luck!
