PCV swap question
Coolant crossover question
I swapped out the valley cover and coolant crossover tubing from my '97 to the newer layout.
My question is: Where does the rubber tube that comes off the crossover tube plug into? I thought throttle body but wanted to be sure. I did the ls1howto install but this isn't covered in there. Thanks!
Received 1,261 Likes
it goes to the throttle body or you can bypass that and go directly to the radiator
