HELP,,,, Memory Problem with Sport Seats
My Memory Function is not working. The seat does not go back when pulling the Ign Key or Opening the Door. And If I move the seat back and push Mem 1 or Mem 2 the Seat does no move
No Codes in any system.
When I program the seat, the LED Flashes. When I push the Mem "1" button the LED illuminates briefly but the does not move forward
All of the Function in my Seats operate with the seat switches, Up, Down,,,, and the Bolsters.
Not Sure, But I think this prob started after disconnecting the Battery when I removed the Front Bumper Cover.
IDEAS ???
IDEAS ???
thanks...\\
Michael..
I've read where the Fob may have some influence on the seat memory, or better said,, programming the seat memory position. But, I don't see what the Fob would have to do with setting the seat memory.
Checked, no codes.
I'll try the Fob, see what happens
thanks...
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you PROGRAN the FOBs,, they program as FOB-1 , FOB-2 and or FOB-3 (if you have three fobs)
The BCM knows what FOB you use to open / unlock the car. When you UN-LOCK the car and program the memory, the memory functions that get rememberd are the radio functions, seat positions mirror positions HVAC function, HUD Display etc etc....
TRY to RE-PROGRAM "ALL" your FOBS using the FOB training function in the DIC.
Mark which FOB is 1 and 2.
When the FOBs are retrained, unlock the car, with say FOB-1 and then put all the MEMORY recall functions " radio functions, seat positions mirror positions HVAC function, HUD display etc etc.... " to SOMETHING. Press and hold MEM-1 on the door until it blinks.
Then set the radio functions, seat positions mirror positions HVAC function etc etc.... to something TOTALLY and radically different that the FOB-1 settings. Set MEM-2 to that FOB.
Get out/ lock and un-lock the car with a FOB and see if you retain those memory functins for that FOB. Do the same for the other FOB.
Also try to cycle the seat motors through their FULL SET OF TRAVLE RANGES (UP, DOWN, FWD, REV) Set the seat full forward and see if it will EASE ENTRY to the full rear lower setting
Bill
Bill
Bill
Bill
I'll do this process this evening, makes perfect sense. I only have one Fob, need to get a spare. No one drives my Cars, well the performance cars, other than the HHR, so one Fob is okay - but a spare would be nice.
I get your point to change the mems for 1 & 2. I'll try this and see if the Fob unlock updates the memory for all of the devices. This did start after the battery was dis-connected for a few weeks.
thanks for taking the time !!
Michael...
Bill
Bill
Still,, No Codes.
I just want the Easy Entry to operate, Dang....
You know, after reading about so many electrical prob's and the grounds being a culprit to much of the Vette Electronic issues - I get so Frustrated. The Corvette have always had a place in my home. They are great Cars, but a little more effort on Bowling Greens Team would noteworthy.
I'm an Electronic Engineer, retired. And my Dad, Grandfather, Uncles,, all Engineers. I grew up with the Electronics and it is wonderful. But still, I'm not a proponent of the gross number of Electronic Modules it in Auto's. The Designers and Management have gotten Damn sloppy. Plus, isn't it about time to design standardized modules and all the bennies that come with ??
It's pretty much common knowledge in Electronics, that grounds and H2O can be death traps in Electronics.
I own three Vettes and a couple of other Chevy's My 56 Chevy 210 Coupe is LS1 powered with a T56, I'm so thankful that She only habitats the One LS1 PCM Computer Module. And that is about to happen to my 87 C4 Vert, gut the entire Electronics (and related wiring) and utilize a single LS1 PCM. I cansee the the two C5's will challenge my patience
Okay, I've vented my frustrations now.
The only electronic doodad in the C5 I care for is the HUD. Easy entry would be the last thing. When GM interviewed people about what the C5 should do I am sure they said "I want this and that and oh, BTW maybe an engine too".
Esp the part on the Ign key and steering wheel lock.
I'm going to ticker with the Easy Entry once more this AM, then that's it for a long while -- too busy. .
Unfortunately 35 miles from home and nearly at a Street Rod Event,,, my clutch pedal went to the floor. Seems to have a fluid leak. I'm praying that it is the master cylinder or hydraulic line. Not the best time for me to be tearing down for a "hyd T.O. bearing". I filled the res with fluid and made it home, only one stop.
Guess I need to replace that fuel pump relay "Connector" in the old reliable C4 Vert so I have something to play-in for the rest of the Summer, what's left...
