passenger window stuck halfway down
Hello guys I have a 1999 FRC. My passenger window was rolled down halfway and stopped there. Then the passenger window would not come back up. I tried both the ups switch on the driver side and the ups switch on the passenger side. Neither would move the window up or down. I disconnected the battery and then magically the window was able to go up again for some reason. Is this some sort of grounding issue is it a common problem? I sifted through some posts and it seemed like there was some corrosion issues on the switches?
