rear end steps out after hitting bump
Old 08-30-2015, 01:28 PM
kennedy759
kennedy759's Avatar
Default rear end steps out after hitting bump
on my 97, when I hit a bump at speed the rear end wants to step out to the left. this question was asked back in 2012 and one of the answers was the trailing arm alignment shims had fallen out. I can not find any reference to a trailing arm in the service manual, so what could cause it to step out?
Old 08-30-2015, 03:16 PM
dbarrym
dbarrym's Avatar
The C3 uses trailing arms, not the C5. First suggestion would be to check your rear alignment settings and a general look over for loose bolts, leaking shocks, broken or loose swaybar links or bushings.
Are you on the throttle hard(ish) when it skips left?
barry
Old 08-30-2015, 03:39 PM
kennedy759
kennedy759's Avatar
cruising on the freeway at 70-75mph on trip to carlisle. added zo6 sways and shocks, all bolts are tight, and it drove ok, then had it aligned and been bad ever since, going to take it to a better alignment service and have them check it out. just wanted a clue as to what else could be wrong.
Old 08-30-2015, 06:48 PM
Forcedvert
Forcedvert's Avatar
Are tires good?, mine got squirly when hitting bumps on not completely worn out tires. I got new tires and it was like a new car.
Old 08-31-2015, 08:07 AM
vettenuts
vettenuts's Avatar
Mine did that all the time with the run flat tires from the factory. One of the major reasons I took them off.
Old 08-31-2015, 08:25 AM
Cybermind
Cybermind's Avatar
Bad shocks would cause the symptoms you're describing but since you state you just changed them, we can rule them out. Unless they weren't new. Problems caused by bad shocks or springs or other suspension components are just amplified by a proper alignment.
When your rear steps out or hops over a bump, this means that your suspension is not doing its job of keeping your tires planted to the road surface. Springs and shocks are the first thing I'd suspect.
Old 08-31-2015, 03:40 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bad shocks were my first thought. Second was a BAD ALIGNMENT.
If it was aligned properly and you indeed have new shocks, you will have some worn suspension parts somewhere.
What shocks did you install????
Bill
Old 08-31-2015, 05:49 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Shocks could do it, worn tie rod could do it, bad alignment can do it....
Depends on how big of a bump it is. Might want to look at checking bump steer on the car.
Lastly...to some degree a leaf spring car will tend to step out over rough pavement. Coil over cars generally do not do this...again as long as everything above is correct.
First check what you have and make sure nothing is worn out/broken/or miss aligned.
Old 08-31-2015, 08:04 PM
SaberD
SaberD's Avatar
always ask for the print out from the alignment machine before you pay them and take it home.
Old 09-08-2015, 01:02 PM
kennedy759
kennedy759's Avatar
fixed the problem with a new alignment, the right rear had a toe of .24, now I know a little bit more about alignments.
To rear end steps out after hitting bump
Quick Reply: rear end steps out after hitting bump
