Side-to-Side Play in Shifter While in Gear (shifter assembly not the issue)
Hi, hopefully someone has seen this issue before, I was unable to find anything that applied while doing a search. First, my car has the RSD short shift and a customer RPM TR6060 with C5 back cover and main shaft to mount to my also RPM built 3.73 rear end. Trans and rear are nearly brand new with less than 5,000 miles on them, slightly over a year old.
Last year during a 3-2 downshift the car got "stuck" in 2nd. I stopped the car and was able to muscle it back to neutral. After that the car would go into all the gears and shift perfectly. However, later on I noticed some new play in the shifter while in gear. I'd say probably half an inch in either direction and seems consistent no matter the gear. As I mentioned, this does not affect the smoothness of shifting and even redline shifts feel fine with no notchiness or grinding whatsoever. I've probably driven the car a couple thousand miles like this and it's fine, just doesn't feel nice to have play in the shifter. I had almost convinced myself it was normal until driving my friend's 09Z and noticing that his TR6060 it dead-tight while in gear, how mine should feel.
I have taken my console apart twice and gone through the whole shifter and shifter box alignment process, just to make sure that wasn't the problem. The second time I checked everything I was able to confirm it was not related to the shifter in any way. When you move the shifter side-to-side in gear, I was able to see the entire linkage moves with the shifter. You can see the rod moving in unison with the shifter, beyond the bolt that is typically the cause of these issues.
This tells me the issue is something in the remaining part of the linkage that I cannot see or inside the trans (really hope not!!!). My mechanical ability ends with taking apart the console, so my next step will be to have my shop take a look. But, before I do, I'd like to get an idea if there is any easy/common stuff they should be checking before the labor bill gets out of hand for something that really isn't affecting my ability to drive the car. Could something with the detent spring in the trans cause this type of behavior?
Thank you so much as always for any assistance that can be provided!
Bill
Bill
You have not convinced me at all that it could not be internal to the shifter. Before you tear into the tranny just put your OEM shifter back in and see what happens.
Mr. Sam
Mr. Sam
If you're positive the rod turns with any side to side movement of the shifter then it has to be the shift rod or inside the transmission. Knowing what the shift linkage inside the transmission look like, I'd guess it is a damaged flex joint in the shift rod.
Yes, I know but there may be slop in the box allowing the motion. However, I can' say how much slop is naturally limited at the tranny. If the tranny has a very tight tolerance then yes the issue is not in the box.
Thank you for advice. I would also be interested to see if the box is somehow controlling the motion while in gear. From playing around with it I don't believe that is the case. I no longer have a stock shifter, but if there was a chance that was it, it would be cheaper for me to buy a C6Z shifter and box than to pay many hours for a shop to investigate.
The linkage rod going back is attached to the transmission with a roll pin. You have to pull the transmission to change it.
You could pull/push that boot back to see if the joint has play. It's basically just a thin rubber tube covering the joint. There's another similar joint at the transmission end of that rod.
How is your C5 beast coming along?
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
The engine and drivetrain is in but shop has been so busy I haven't touched it in few months. Your own car is always last to be worked on. lol
Replacing shifter rod
how do I replace that part number you mentioned? And where can I buy it other than gm?
