2001 C5 Shocks
3rd Gear
2001 C5 Shocks
I've recently acquired a 2001 C5 vert that belonged to a family member that passed away. So far I have found it has Kook headers, XPipe, Billy Boat PRT exhaust and the RadioFlyer Stealth Light Cannons. I have been reading the forums like crazy trying to learn what I can.
I would like to replace the shocks and have read that the C6 Z06 shocks are a favored and direct bolt on for the C5. Can anyone point me in the direction of the part numbers for these...am unsure what year C6 I should be looking for. Also are the front left and right the same part number as well as the rear left and right or do all four have different part numbers?
Thanks for any help.
T
T
c6 shocks
I would contact Gene Culley at Cultrage performance. He is a forum vendor and will help you out. I have purchased from him and he is very good about keeping you informed about your order. Good luck with your repair.
Vincent
Vincent
3rd Gear
Shocks from any year C6 Z06 (or any year C6 base for that matter) are a direct bolt in replacement. Front shocks are different from the rear shocks. No difference left or right.
Does your car have the F45 RPO?? ( There would be a switch on the center console allowing you to select from 3 different ride selections.) If yes then you cannot just swap in a NON F45 shock.... The F45 RPO needs to be either deleted or bypassed or you will have the vehicle speed limited to 80 MPH.
Thanks again.
T
3rd Gear
Once you have part #'s also look on rockauto for them. You may get them cheaper than elsewhere. The ride was excellent when i did it. It was not to firm and i added the newer sway bars too.
Chris
Chris
Hselby (10-04-2015)
Received 19,225 Likes
'20-'21-'22-'23-'24
Sorry to steal your thread todd5250. Hope you don't mind.
I have a 2002 C5 Vette with 113,xxx miles. I do'nt know if they ever got changed by previous owners. So I have 2 questions-
How often do you change your shocks?
So C6 Z06 are better replacement shocks than the oem C5's?
The C6 Z06 shocks are much cheaper than the 97-04 OEM shocks. That's one of the main reasons the C6 shocks are recommended. I'm sure there are performance gains from the Z06 shocks but I'll let someone else chime in on specifics.
The base C6 shocks are also much cheaper than the c5 base. I have the C6 base shocks,
and they are working great. Maybe softer than the Z06, but they eat up bumps better.
If you lower the rear too much, then you need a stiffer shock to help with rebounding constantly off the bump stop due to lack of travel.
I upgraded to the C6 Z06 shocks and Love them.
Premium Supporting Vendor
Thank you all very kindly for the referrals. It is certainly appreciated. The C6 Z06 shocks can be ordered on our site at the link below.
http://www.cultragfactoryparts.com/c...t/c6z06shocks/
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
