Shifting trouble, 5th, 6th
Trouble shifting into 5th, and out of 6th.
5th goes in slowly and with resistance, sixth comes out like I'm hardly pushing in the clutch. Thing is is only does it when the cars been running for a while...
If the car has been sitting everything shifts like butter.
Just redid the master. I took it to a performance shop and they had their hand at pulling any air out of the clutch line after I did what I could. Any thoughts if the slave is dieing, or if I need a shifter alignment? I have done that twice in the past. Not much has changed from it.
Wondering if the shifter rod is bent, or perhaps a transmission mount or something along those lines is worn and causing things to be ****-eyed.
Thoughts?
Thoughts?
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Thoughts?
Thoughts?
