need helping choosing main and rod bearings
Cruising
need help choosing main and rod bearings
hello i have a 01 c5 with a ls6 block a couple weeks ago i had a ls7 lifter fail it collapsed. i pulled the cam and the cam bearings have groves in them i also have metal in my oil so the engine is coming out and getting sent to the machine shop for all new bearings im not sure witch ones to choose i have heard king, clevite H, clevite P, are good not sure what i should get or some other brand. the car has stock ls6 crank, forged pistons and rods with a novi 2000 running 11 pounds of boost and makes 605 whp i want to put something in there that will last.
All the suppliers you listed have comparably good products, for what it's worth I just had my shortblock rebuilt and had the machine shop use King coated race bearings...... Very satisfied so far
Cruising
Thank you for the help but after doing some more research Im going to go with some clevite HK series ones that are tri metal and have the Molly graphite coating
