Power Brake Booster Help
Old 10-18-2015, 02:43 PM
Joshboody
Joshboody's Avatar
Default Power Brake Booster Help
Had a leaky booster, replaced with ACdelco remanf unit. Now I have a hard pedal with NO assist. Brakes are working though.
Guess I received a bad booster. But maybe I could have missed a step prepping the new one?
This was a super sucky job and doing it again... HOLY CRAP!
Old 10-18-2015, 03:28 PM
zachaeous
zachaeous's Avatar
Default brake booster
I would check it using this procedure assuming you have vacuum getting to the booster:
This procedure will require the use of a hand operated vacuum pump with a vacuum gauge. If you do not own one it can often be rented or borrowed from most “big box” parts stores. (Note: 18”HG is the minimum engine vacuum at idle in gear to effectively operate a vacuum booster
1) Remove vacuum hose from check valve on booster. Place hose from vacuum pump onto check valve and draw booster to 20” of vacuum.
2) Let booster sit with vacuum applied for 5 minutes. If vacuum does not stay steady at 20” it is faulty and needs to be replaced. If vacuum does hold steady at 20” proceed to step 3.
3) With 20” of vacuum in booster depress brake pedal once and release it. The booster should transfer some but not the entire vacuum in reserve. Depending on how hard the pedal is depressed it is normal to see 5-10” of vacuum depleted from reserve. The most important thing is to ensure the booster does transfer vacuum but does NOT transfer the entire vacuum in its reserve. If vacuum remains at 20” OR goes to zero the booster is bad and will need to be replaced. If vacuum transfer is within the above parameter proceed to step 4.
4) Once again draw booster down to 20” of vacuum. Go inside car and depress brake pedal and hold down for 30 seconds. You should see the gauge drop slightly and then hold steady. Vacuum should stay steady as long as you are holding the pedal down. If vacuum drops while pedal is being held down the booster is faulty and will need to be replaced.
Good luck
Old 10-18-2015, 03:39 PM
Joshboody
Joshboody's Avatar
Thanks, I'll try that.
To me it seems the other side is not pressurizing, letting atmosphere in once pedal depressed.
At least I think that's how they are suppose to work.
Old 10-18-2015, 10:02 PM
Joshboody
Joshboody's Avatar
I have 2 mityvac type, but could only get 8 or 5" depending which I used. Bleeds off slowly, but more pump/lines I think.
Seems there could have been cover or something hindering air getting in thru rod area that I missed. If so, prob have to pull it out anyway. Gonna suck!
Old 10-20-2015, 02:25 AM
Joshboody
Joshboody's Avatar
It was a bad remanf unit, replaced again and 2nd works fine.
Second time doing the job, not too bad.
FYI: don't have to remove brake lines to master, can just move to alternator area.
zachaeous (10-20-2015)
To Power Brake Booster Help
Quick Reply: Power Brake Booster Help
