Door Lock Relays - Part II
Rather than add to an already long thread, I thought it best to start new one to see if anyone could address my particular problem which seems to be related to the Door Lock Relays.
Original thread - Door Lock Relays - A Picture is Worth A Thousand Words
My driver's side door lock began malfunctioning a while back, it will not un-lock electronically. (It locks and un-locks manually.)
1. The door will lock electronically with the FOB and/or door switch on driver's side and passenger side doors.
2. Passenger door locks and un-locks electronically with the FOB and/or door switch on driver's side and passenger side.
3. If I run 12v directly to the door lock solenoid it will operate the door lock (lock & unlock) fine.
I went through the link above and read about changing out the door lock relays that seems to solve this problem for a lot of folks. I purchased two of the listed solenoids and installed them on the Door Control Module (DCM) circuit board as illustrated in the YouTube video. I reinstalled the DCM in the door and connected the "door switch assembly". Everything functions as before, windows, mirrors, locks, etc. Drivers door still does not un-lock electronically.
When I lock the doors electronically, the relays in the DCMs on both doors can be heard clicking. When I un-lock the doors electronically, the passenger door relays can be heard clicking (and unlocking), but the driver's DCM relays do not respond (no clicking) at all.
I purchased a new driver's side "door switch assembly" and everything remains the same.
At this point it seems that I need to find a driver's side Door Control Module unless someone has any ideas on what to check next.
Thank you for your assistance... GUSTO
i have replaced the replays and seems to fix the problem. Sounds like if you have done that already you might try and get a used one form either one of the Corvette recyclers on the forum or find a used one on ebay. we have swapped out bad ones with used ones on ebay and seems to do the trick as well.
S
S
Gusto, how are you doing with the exception of this?
Yes, I agree with you it points to the LDCM as the issue. I can not explain anything else based on your diagnostics.
Marc at VetteNuts.net is a great Forum vendor here for used parts.
If you feel like you want to discuss on the phone first, please feel free to PM me.
Mr. Sam
Mr. Sam
Mr. Sam
Mr. Sam
Thanks for all of your assistance.
GUSTO
