How hard to switch a Window switch ??
Better to disconnect the neg battery cable first, no need to take the door panel off.
Ah just seen your pic- no need to worry about breaking the old one! Just don't drop the connector into the panel save some fishing.
Getting the switch back in place is harder than getting it out. When you get it out you'll see there's basically a hook on the front, and a tab on the rear. When installing the new switch, slide the hook under the front of the hole, then push the switch as far forward as you can--that will help you press the tabbed end into place.
SaxyVette (11-29-2015)
