C5 Fender Accent Stripes
Old 01-12-2016, 06:14 AM
VETTEC599
Support Corvetteforum!
VETTEC599's Avatar
Default C5 Fender Accent Stripes
I recently purchased a set of the stripes from a forum vendor. The install instructions were very good; however, I have a question. Do I wash the car first? Do I wax the car then install the stripes? Do I install the stripes then wax over them? What is the prep I need to do before actually installing the stripes. Thank you in advance for your input!
Old 01-12-2016, 08:50 AM
Received 19,188 Likes on 13,911 Posts
'20-'21-'22-'23-'24
Get the car clean and remove the wax where you are going to install the stripes. Isopropyl or rubbing alcohol on a rag will remove the wax. Then install the stripes. Once done, you can apply wax back over the area, including over the vinyl stripes. I did this to the vinyl stripes I put on the fender of my '00 and did not have any problems in the 6+ years they were on the car.
VETTEC599 (01-12-2016)
Quick Reply: C5 Fender Accent Stripes
