Help installing amp and sub
NCM Lifetime Member
Received 3,930 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23-'24
I am going to be installing an amp and sub in my 03 Z06, and I need a little help.
I know how all the audio and power wiring connects together, my concerns are primarily running the power cable through the firewall to the battery, where to ground the amp in the rear, and how to disassemble the interior to run the wiring to the rear.
I have searched the forum, youtube, and google and found nothing specific to this installation in a C5 Corvette.
Any help is much appreciated.
Pull battery and drop panel on passenger side and use factory grommet
Panel on passenger door sill will pull straight up. Use factory seat stud as ground
Can fit a medium to small amp under passenger seat
lewislgZ06 (02-13-2016)
NCM Lifetime Member
I've got the battery and passenger seat out. Looks like it will fit just fine, just need to get some velcro to secure to carpet.
NCM Lifetime Member
PM sent
NCM Lifetime Member
I tried pulling down on it, but it doesn't seem to want to come out. I don't want to break it, and I don't know how it is secured. There is a white round plastic plug that appears to hold it in. Does it snap out?
NCM Lifetime Member
Disregard pentavolvo, I finally got the panels down and got the wire fished through the OEM grommet and into the cabin. I think that was the most labor intensive part of the install, and I believe I've got it from here.
Thank you very much for the pointers.
I think running power cables through the firewall and interior is a big waste of time, and tough on the interior (and lower back) to say the least. I ran mine easily through the hydro-formed frame, and there is a major grounding point right there too - See here https://www.corvetteforum.com/forums...-c5-frame.html
The other (smaller) wires (rca's and power trigger) can easily be run under carpet from the rear of the console to the amp mount. No panels to be removed, but may have to poke a hole in carpet depending on where you mount the amp (and coupe vs convert).
NCM Lifetime Member
You're looking in the wrong place - there is a separate Audio forum :-)
This is the only social media I use, and I guess I don't understand some of the things about it. I did try to search for the information, but I was unsuccessful. That's why I asked for some help.
I apologize for my ignorance Sir. I didn't know there was an audio forum, and I still haven't been able to find it.
Anyway, this is a link to the Audio Section, but that area is not C5 specific.
There is nothing wrong with asking here and I'm sure you'll benefit from from the experiences of the group.
lewislgZ06 (02-14-2016)
