water pump replacement
I have a base model 2004 C-5 that needs a new water pump. On inspection it has the older model water pump that has the integrated thermostat & housing as a single unit. Will the newer style water pump be a direct replacement (understanding that a new separate thermostat and separate housing is required)?
Top to bottom
LS3-LS7 Corvette
LS3 crate motor
LS1-LS6 Corvette
Also an advantage of LS3/ LS7 over LS1/LS6 is that 92mm and 102mm throttle bodies fit a FAST without grinding on the pump.
LS3-LS7 Corvette
LS3 crate motor
LS1-LS6 Corvette
OP: one thing to keep in mind regarding the LS3 crate version is your upper hose will either have to be modified or replaced due to different location of the hose nipple.
