HELP! Driver side rear brake and turn signal not working...
Having some issues with ONLY my DRIVER SIDE REAR brake light and same REAR TURN SIGNAL not working. Problem has to be related. Both started yesterday.
When I use the driver side turn signal it hyper flashes on the cluster the front driver side turn signal does work but hyper flashes too. But both rear driver side turn lights don't work.
Also, noticed the same thing is happening with both driver side brake lights. When I hit the brake pedal The third brake light and both passenger side brake lights work fine. But both driver side brake lights don't work though.
However, both night time rear driver side lights do work when I cut the head/tail lights on. Sockets also look fine and not corroded.
Looking for some pointers or maybe an easy fix before I have to find some schematics and break out a volt meter.
-Checked the bulbs... Filaments were fine...also switched both bulbs over to the passenger side they both worked just fine. Turn signal and brake wise.
-When I hit the hazards. Same thing. All other lights flash except the rear driver side. Did a Hazard bypass just to make sure it wasn't the pesky Hazard switch. Problem still persist.
Open to even simple advice I may be over looking..
Fuses checked but will re check in the AM. Dark raining and garage is full. What bad fuse would only effect the rear driver side brake and turn signal???
or it can be a grounding issue within the light assy, or the body. do you have aftermarket lights back there? you may can try temp swapping the entire assy from one side to the next, not just the bulbs. this happened to me, but the hazard switch fixed it. I didn't do the bypass mod, I just pulled the dash. hope this helps. I know the hazard switch does several things.
No single fuse that effects ONLY the left side brake and turn signal. Fuse #8 in the passenger footwell services the tail lights on BOTH sides But there is a ground at G401 that is for the left side brake and turn signal. Actually it is SP400 (SP = Splice Pack) that goes to G401.
Here are a couple links on C5 grounds that may help:
http://forums.corvetteforum.com/c5-t...locations.html
http://forums.corvetteforum.com/c5-t...tion-long.html Post #1
Personally I think the problem will finally sort out to be a problem with the Multi-Function Switch. JMHO
There
There
Exactly what i was getting at. If it was a fuse it would effect both sides of the action.
That ground info is a good next place to start. Thanks again.
How could the multi function switch effect the brake lights? I was guessing that they were run off a separate brake switch. Any other ways to tell if the multi function switch is bad? That seems like worse case scenario. I do have a multi function switch off of a 98. But i have no idea if its good or compatible since this is a 2000. Plus the lettering on the handle is pretty faded and worn.
Any other ways to test the multi function switch??? How does the multi function switch effect the brake lights individually?
Thanks you seem very knowledgeable. Seen your info in a lot of light post.
Update.... pulled the multi funtion switch since the kick panel was already off and 2 people on here more knowledgeable than myself suspected it. I also have a 1998 race car c5 that is gutted but still had multi funtion switch but was litterally a 2 minute pull off job since its gutted. The harness and connecter was the same so i plugged it into the problem car. Same exact thing all funtions work on the multi function switch except driver side rear turn signals and still no rear driver side brake lights.
I guess that rules out multi function switch
The brake and turn signal lights are the same filament. If the MF did not fix it you will need to pull out the multimeter and trace the issue.
If you need any schematics I have that to post at home. There is only one ground for all the lights in the rear.
Should not be too hard to find the issue.
Mr. Sam
Mr. Sam
Mr. Sam
Mr. Sam
The ground is the g401 that 8vette7 listed earlier right? its on the outer frame rail right behind the rear tire... small...was pretty clean. Plus it grounding other stuff that is working. What should i do?
my apologies. I worked this issue with a couple of experts on here. and now that I'm remembering. I had to do the hazard switch, and the mf switch. thanks dadaroo. this was after my ipc wire harness caught fire.
Bump getting ready to jack up the car and try to test the harness...Any suggestions? Where does the rear light harness plug into???
Well that was quick, FIXED IT.
THE FIX!!!!!!!!!!!
Found a crimped wire in the harness by the battery. Played with it and the turn signal came on. Cut wire stripped it and fixed it right. Brake light working too.
Now I get to put the car back together again.
THE FIX!!!!!!!!!!!
