02 Zo6 Airbag light
Cruising
02 Zo6 Airbag light
So I bought this car from a guy here in VA, the car sat garaged in TN for two years after he bought it from another fella in Houston, where it's original engine was blown missing 2nd gear.
The guy I bought it from is pretty mechanically inclined, yet had other toys to mess with. Luckily he sold me his z and I'm a happy camper, well as soon as these light go off I will be.
The ABS, Traction lights were on so I pulled the EBCM. I'm currently awaiting for the EBCM I took off to come back, slap it in, hopefully then it takes care of those lights.
Now my airbag light has yet to turn off. I've taken the horn/ air bag module off to check the plugs, and all is well. Even disconnected the plug under the steering wheel, that one was a bit oily, but I sprayed it with some alcohol and dried it up. Still nothing. I checked all the fuses, and nothing. I really don't know where else to look. All seems well but I get nothing.
The only codes I get now are the following:
10- PCM P0102 H C
PCM P1571 H C
PCM P1689 H C
28- TCS NO COMM.
58- SDM B0026 H C
U1040 H C
I get the B0026 deals with the airbag light, but in no way can I find what the heck is wrong with my car.
Any help or guidance will be greatly appreciated.
(2002 Zo6 manual):
10- PCM P0102 H C
PCM P1571 H C
PCM P1689 H C
28- TCS NO COMM.
58- SDM B0026 H C
U1040 H C
(2002 Zo6 manual):
There are several things that can cause this as I have learned because I have the same problem. Mine is because the original BCM has been replaced (by me while trying to fix another issue) and the new BCM is not correctly recognizing the existing air bags. That can be fixed but there are parts that have to be reset by a trained tech with the right equipment. Computer make things so much fun! For me, I will be replacing the new BCM with the original one as it turns out that nothing was wrong with mine.
There is also an airbag sensor down near the steering column that could be bad and needs attention. Also, the yellow wire in the steering column that hooks to the airbag could be loose at the airbag connection. There are specific steps that have to take place to safely remove the airbag to check that.
Search the sticky thread about Important Electrical Information for "airbag" at the top of the C5 Tech section and it will have much more detailed information.
Cruising
Hey thanks Casey Jones, I did try the sensor near the steering wheel but nothing. As with my EBCM shoot mine is fried. Well it looks like it had water intrusion and everything in there corroded. But I'll keep fiddling with my airbag dilemma until something happens.
I'd check the yellow wire and the BCM. I fixed mine today by putting hte old BCM back in it and running through the re-learning procedure.
