Trans install question (intake manifold)
Im still waiting to get my trans back, but want to get a head start. Will i make my life harder if i reinstall the intake? I removed it so i wouldnt crack it/firewall on the removal. I was also going to install the LT headers and quicktime bellhousing. Does anyone see this being an issue?
Received 1,261 Likes
I have removed my drivetrain twice and didn't remove the intake, as a matter of fact it didn't even get very close to the firewall... I think you would have to lower the drivetrain quite a bit past the bottom of the rear tub to cause a problem so you should be fine installing the intake beforehand... you should be able to install the bellhousing as well and on the headers you can slide them in place but will most likely need to leave them hanging in order to have room to access the torque tube to bellhousing bolts... I always just leave the headers hanging but supported by jack stands and reinstall them after the drivetrain is back in place
I think if the headers are off the car completely I would leave them off. I let mine hang and they were quite frankly always in the way and the job was more time consuming as a result. As for the intake, I am running a FAST and removed that as well because it was too close for comfort.
