Left side of radio audio is out
Hello to all, I did a search for this issue and came up empty so I thought I Would ask the group. I noticed that I was getting audio out of only the right side speakers. I checked the left and right balance and that was set to the center. A little while later, I drove over a big bump and the audio came back on again. Another bump and it was gone.
With the balance set on full left, I still do get a little audio out of the speaker. It sounds faint and tinny sounding. I am wondering if this is a wiring issue or a radio issue? I did check the door rubber wiring boots and that did not make any difference. Before I tear into the radio, are there any wiring checkpoints that are easily accessible that I could check. Any other ideas to solve this will be much appreciated.
Steve
Steve
If you still have the OE radio, it's the circuit board. Very common on GM radios of this vintage for one side to cut out. There are several outfits you can send it to, or buy a new one on eBay for $250, or go aftermarket.
Incomplete information
Steve
The stock front woofer speakers have spade lug push on connectors that may have come loose, or off. The "tinny" sound you're describing sounds like the tweeter is still working but the woofer is not.
I experienced this on my Hardtop a number of years ago. I squeezed it a bit to make it fit tighter and pushed it back on. Remove the door panel and check. Easy fix if that's the problem.
HTH
You can see the two woofer push-on connectors here. The subs fire outwards so that's the back of the speaker you see:
HTH
flyboyslc1 (04-23-2016)
Like that Clinton picture
HTH
HTH
LoneStar rocks!!!
HTH
HTH
Great info on the forum! I salute you LoneStar!!!
steve
Nice ... thanks for posting your results... Lonestar and dadaroo are some of the best on the forum ... follow their post and learn.
