cat removal
Old 05-04-2016, 05:43 PM
painterman98
painterman98's Avatar
Default cat removal
can I remove the cats without having to retune?
Old 05-04-2016, 05:48 PM
bwill03z
bwill03z's Avatar
You will throw a code if your rear o2 sensors haven't been turned off. I've ran catted and non catted and unless I was making 500whp or more I would leave the cats on.
Old 05-04-2016, 05:50 PM
grantv
grantv's Avatar
Yep... as noted above. What's the reason for wanting to remove?
Old 05-04-2016, 11:29 PM
Support Corvetteforum!
Received 19,187 Likes on 13,911 Posts
'20-'21-'22-'23-'24
I would leave the cats on a stock to moderately modded car.
Old 05-05-2016, 03:44 PM
Rx7Rob
Rx7Rob's Avatar
If you can find O2 sims you won't need to reprogram the rear sensors.
Old 05-06-2016, 03:34 PM
painterman98
I was able to do what was needed and leave them on
To cat removal
Quick Reply: cat removal
