Dash Pad Pulling Away From HUD Bezel
My HUD is working fine, the HUD bezel is not cracked and the dash is not cracked. However, the dash pad is pushing up so you can see the dash padding around the front of the HUD bezel (toward the driver). I know that the dash must be removed to replace the HUD bezel or HUD itself. However, when looking at how the HUD bezel is attached to the dash, I do not see how it has any adjustment to move back over the dash pad. Anyone else having this problem? Better yet, anyone find a cure to this problem?
Thanks!
Thanks!
I just had my dash apart a couple weekends ago to fix the dropping HUD issue. The bezel and the dash pad are functionally the same piece. It sounds like your bezel is separating from the dash pad. I'd recommend some sort of strong adhesive to rebond the two. There might have been clips underneath holding it on (I don't remember) and maybe one of your clips broke or something.
http://www.c5hudbezel.com/c5-corvett...-retrofit-kit/
Was not sure if it would be larger than the factory bezel, thereby pulling the dash pad back down??
That is what I was afraid of. No, no clips or anything broke, the dash pad is just pulling away, ever so slightly to cause the dash to push up. Is this the solution?
I can't see the link (I'm at work) but I'm guessing that is more of an overlay solution for broken bezels. A picture would probably help but I'm guessing you just need a little dab of glue on the pad and shove it back under the bezel. How big is the gap or area that we are talking about?
Will see if I can get a picture. The gap is very small, however the dash is pulling up about 1/2 and inch or so. I can push the dash pad back down and under the bezel just to have it raise back up within a few minutes. Adhesive would work, just do not like the idea of gluing the dash material to the bezel, in case it ever does crack or HUD ever goes out.
Without seeing any pictures it sounds like the typical issue of the vinyl shrinking on the dash pad. Mine did the same thing in the same area around the HUD bezel. I picked up a couple feet of "black welt piping" from a local upholstery shop for a few bucks and tucked the flat portion between the bezel and the dash to cover up the exposed padding. When I get home I'll try to take a picture of it so you can see.
MorganZilla (10-23-2021)
Received 19,286 Likes
'20-'21-'22-'23-'24
Mongo - that looks like a pretty good solution to the problem.
Mongo, this is exactly what I need to do! I think this would fix the problem. Can you provide the steps taken to do the job? Does the dash need to be removed? Plan B would be to get a new dash pad, which are not as expensive as one might think.
Vetteman Jack, you go to the show last weekend? Nice turnout. I did not show the OAZ, but was there to walk around. My favorite Vette was actually parked across from Arris Pizza / post office, a pristine red 66' coupe. Am going to try to make the next cruise in at the mall.
Andy
Andy
I did it with everything still on the car, it was a bit tough the closer you get the windshield but not impossible.
I just took the welt piping and started installing it from the windshield of the driver side and wrapping it around by tucking the flat portion between the bezel and the dash pad, once i got it around to the passenger side I measured with a ruler from the point where the piping would disappear under the windshield to a given point on the piping. I pulled the piping back, cut off the excess and finished tucking it back in.
