Lost some EBCM bolts
I was putting it back in the car after getting it back from abs-fixer. Dropped two bolts and after an hour of lifting the car and checking every angle can't find them. Anyone know where to order new ones?
Premium Supporting Vendor
I responded and you placed an order?
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
I bet they went behind the control box. I did the same thing and when I had to remove it again for something else there they were. There is a spot on the back of the unit that will catch them.
Got the bolts from Gene, thanks!
Found one bolt when I moved the car, seems like the other one found a new home.
Seems like ABS Fixer solved my random BCM code-throwing issue.
