Check engine lite, I have the codes, what to fix??
Ok, My 2003 got check engine, pulled all the history codes, deleted them, then went 10 mi. came back this is the new code
P0442 - "Evaporative emissions (EVAP) systemSmall leak detected PCM engine controls"
this was one of the codes that was in history.
I know PCM is the power train module under the batt. but what would be the issue and the fix ??
I checked gas cap and made sure it was tight
Jim
Jim
jdsaengine (05-23-2016)
Just get a NEW gas cap...
so this code is usually associated with the gas cap, not the 50 ft of rubber hoses under the hood that might have a hair line crack somewhere?
I sure would rather replace the cap than attempt to track down a hose leak.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It could very well be SOMETHING ELSE but,,,,,,,,,,,,,,,,,,, ITS VERY VERY VERY common to have a deteriorated gas cap O ring in the cap.
Examine the O ring... I bet its all cracked and chewed up! Pop off the cap and look.
Beeeeeeeeen there and seen that,
BC
BC
got a new cap at Penske Chev down the street ($35) Drove about 20 mi. start and stopping at various places and no codes Looks like a fix. thanks all
CI 6,7,8,9,11 Vet
St. Jude Donor '08
HE usually is
