Key Fob Problem
Key Fob Problem
I have to sync my key fob with my 2000 coupe at least once a day. Holding the lock and unlock buttons for 7 seconds will sound the horn. Later in the day, I have to sync it again. Also, the chime no longer sounds when the door is open and the key in the ignition. I assume the problems are related since they occurred at the same time. I suspect a problem with the body control module. Anyone have a similar problem? Any advice?
