Headlights won't turn off even when car is off
Old 07-01-2016, 12:18 AM
Cloyie Hughes
2nd Gear
Cloyie Hughes's Avatar
Default Headlights won't turn off even when car is off
I have a 2000 Corvette, My headlights are stuck on even when the car is turned off any ideas on what could be causing this type of problem and how to fix it? My twilight feature is turned off I tried turning it on and back off etc. Only ways They turn off is with the fuse under the passenger side removed or with the battery cable off....
Old 07-01-2016, 12:20 AM
medic3009
medic3009's Avatar
is it a manual putting the car in reserves shuts off the battery on my c6 idk if yours will do the same since its older
Old 07-01-2016, 12:22 AM
Cloyie Hughes
2nd Gear
It is a manual 6 speed and I tried it just now and it didnt work. But thank you for the advice.
Old 07-01-2016, 12:39 AM
medic3009
medic3009's Avatar
Sorry that didn't work figured it be worth a try I would disconnect your battery until you can figure a solution so you can limit future problems
To Headlights won't turn off even when car is off
Quick Reply: Headlights won't turn off even when car is off
