Grease buildup inside right rear wheel rim
Old 07-01-2016, 06:53 AM
NewRocketGirl
NewRocketGirl's Avatar
Default Grease buildup inside right rear wheel rim
When I got the new tires the other day, one of the mechanics noted there was an excessive building of grease inside the right rear wheel rim. I would say in areas it is almost 1/8" thick. Any idea where that might be coming from? I am not having issues, but I wonder if there is some sort of rear seal leak that needs to be fixed. Is it okay to drive until I can get it to the shop after the holidays?
Old 07-01-2016, 08:07 AM
Macleod52
Macleod52's Avatar
Check your tie rod ends. Maybe one of the boots are damaged and the grease is coming out of them.
Old 07-01-2016, 08:24 AM
nsogiba
nsogiba's Avatar
Could be outer CV joint leaking grease as well. I would recommend cleaning the wheel completely, then driving it to find out if fresh grease is still leaking out.
Old 07-01-2016, 08:42 AM
Pounder
1/4 mile/AutoX
Support Corvetteforum!
Pounder's Avatar
Received 2,081 Likes on 1,634 Posts
with the previous, did you find out what your other fluid leak was ???
Old 07-01-2016, 08:57 PM
feeder82
feeder82's Avatar
outer cv boot is leaking, probably a tiny pin hole hard to see
Old 07-01-2016, 09:51 PM
Received 19,187 Likes on 13,911 Posts
'20-'21-'22-'23-'24
Would be an area I would check first.
To Grease buildup inside right rear wheel rim
Quick Reply: Grease buildup inside right rear wheel rim
