Help with clutch decision!!! Please
Ok. Story. I recently bought my first Corvette. 97 6spd. Guy I bought it from showed me a reciept for a new clutch and slave, looks like the master was done also. The pedal is sooo stiff my leg keeps cramping up in traffic. My brother (a GM tech) drove it this weekend said of all the C5 sticks he has driven. Nothing had ever been like that, stiffness and slight vibration while revving the engine. Possible the flywheel being out of balance. The clutch kit that was put in was a K50185-1 kit from the local auto parts store. I really want it fixed right. Any advice on a pretty much stock vette clutch would be appreciated. I don't want anything crazy just factory feeling and reliable as I am not going to race it or pull sick HP out of it. It seems that the factory clutch disk is no longer manufactured by GM. so it seems like that is not an option.
Thanks. I'm watching that thread already. Trying to figure out why the pedal is so damn stiff. If I can fix what's in there already I'll leave it.
Running Guns & Moonshine
If you're looking for a new clutch, I HIGHLY recommend the McLeod RST. RXT if you're going to go nuts with power - that one holds 800+ tq?
Super light pedal, guaranteed grip, inexpensive to rebuild/upgrade.
Having had an OLD spec 3 clutch in a trans am years ago which cramped my leg in a traffic jam so bad that I had to clutch by pushing my knee with my left arm one time... I know your pain! McLeod for the win.
Personally for my car I'll be doing a monster stage 2 package from tick with an 18# flywheel. I don't intend to ever make more than 500 hp. Vibration is more than likely your flywheel. Most people cheap out on balancing clutch components.
As far as your super stiff pedal the only thing I could think of is a gross oversizing of your master cylinder. What's your pedal travel like for engagement/disengagement?
SNL/MonsterClutchCo (07-23-2016)
Yes the fluid does look pretty dirty. I will check and see what the make on the master cylinder is. Maybe replace it with factory gm, then flush the system and replace the fluid. That seems to be the easiest place to start. As far as the vibration, I'll look into either balancing my flywheel or replacing it later. Thanks for the input guys!
I have read where some track guys "vented" their bell housing dust covers to get more air flow to reduce heat and to keep clutch dust from accumulating in the bell housing...
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The very FIRST place I would start is the MASTER CYL. If its an adjustable, it could be causing the extra peddle pressure.
BC
BC
73Corvette (07-11-2016)
That is sound advice. I can live with the clutch for now if it wasn't so damn stiff. It wrecks my knee when I get stuck in traffic. I'll poke around and see what brand it is and then look into bleeding it and getting some fresh fluid in there.
So I started to clean out the muddy fluid in the reservoir. Syphoned it out and put new in. Gonna run it for a bit and try it again. Didnt seem to help at all. Has anyone used ZIP CORVETTE for anything, are they reputable? I see that they have an aftermarket HD z06 clutch kit. I am thinking of just replacing everything in there with new as I dont know what the guy before me did in there. Like new gm slave, master, and the z06 clutch kit as I know the flywheel needs to be balance anyway. I dont want anything crazy as it stock and I dont plan on doing too much to it. I just want a good pedal and no vibrations. I was thinking of grabbing a pair of the drive shaft couplers and putting them in for good measure as I am sure they are original and 19 years old. Does that sound reasonable?
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ZIP is an outstanding vendor with a very good reputation.. I've purchased NUMEOUS things from them and have been very happy.
Bill
Bill
Former Vendor
LT1-S twin if you want something to drive like stock and hold up to 700 rwhp, with stock drivability and you can abuse the heck out of it. Level 2 is you make less than 500 rwhp and want to do the same with stock drivability.
The adjustable masters will increase pedal effort ~40%, all of our units are designed to work with stock hydraulics, both units mentioned above have stock pedal feel.
Our stuff is on sale right now through the end of the month, I'd take a look at them - www.monsterclutches.com
Has anyone used the torque tube couplers from Corvette Central lately? I am having a hard time swallowing the 130 dollar price of the factory GM ones. I dont even know if mine are bad but since I'm going to be digging into it. I wanted to have a couple on hand just in case they are.
