Help with IP and door problem
03 vert gauges are pegged,nothing on the doors work and the display on the IP is showing all kind of messages. Checked for codes and there was codes in all modules. Radio shuts off and also shows reduced power but it is not. Has full engine power. This started right after my friend bought this car and it only would happen about once a month. Now it will do it as soon as you drive about a block. It has not done it setting in park. I have cleaned the 3 grounds under the hood and the dealer replaced the battery a month ago. I can get codes later today. Help please!
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have a very good suspicion on what it might be BUT,,,, the DTCs will help zero in on what's not happy!
Post them up..
BC
Post them up..
BC
Pro Street (08-18-2016)
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Or the DOOR POWER CONNECTORS and or SEAT CONNECTOR are making poor connections..
