PCM and TAC module
PCM and TAC module
loss of comm when tac module and PCM are both connected. Have replaced TAC module, tested tac module on another vehicle, have replaced pcm, have load tested PAGS. Really at a loss here. can unplug tac and vehicle will start, but no throttle(obviously) but as soon as the two comm lines and ground are connected i lose comm and engine dies.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,,,,,,,,,,,,,,, If it were me,,, I would take the wiring harness and connectors apart and look for shorted/damaged wires/pins.
Go from there..
Do a continuity check on the serial data wire between the tac and PCM
BC
Go from there..
BC
Follow Bills instruction. HE can get you up and running!!!
