car vibrate and a little shaky at idle
2004, z06
46K, manual
3 questions:
1 - once the car starts moving, it seems fine, no vibrate or shaking but at idle, the car seems to shake and vibrate a little, you can feel it coming from the engine, ( it only does it sometime) is this normal ?
2 - i notice it is more difficult to shift into gear when the car is cold, once the car warms up to normal temperature, shifting is much more smoother, is this normal?
btw...i had already change the trans fluid.
3 - I read and heard of the common issue with the harmonic balancer, if i remember correctly, this only effects early c5s and not the 2003s and 2004s? is this correct?
i am worry this may be related to the vibrating/ shaking but no chirping sounds.
Thanks in advance guys.
46K, manual
3 questions:
I have an '01 M6 and notice the same things as you describe in 1 & 2. I assume they are normal.
I'm fairly certain the harmonic balancer affects every year. FWIW my '01 has 92k and shows no signs of wobble (Knock on wood).
Yes, nice little chop.
Yes, a tiny bit; better with the Amsoil.
No, all years AFAIK. Check if you see any irregularities. My 04Z also around 46K, HB seems fine.
GTXZ06 (08-23-2016)
There is some level of shake to the engine as others have stated. Every once-in-awhile, the connection between the air cleaner and intake slips off on my car. Make sure yours hasn't done the same. If it did, you are getting unmeter air into the engine which causes a rougher idle.
