Rod knock or water pump? Dear lord
I really hope this isn't rod knock or other damage
https://youtu.be/tPK-fVtvKiw
https://youtu.be/GnKy2tLvsNQ
1/4 mile/AutoX
it doesn't sound like a rod knock, unless it's really bad ??? tensioner ???
1/4 mile/AutoX
with a knock that bad I would think the oil pressure would be way down ?????? take the belt off and see what happens then ???
2015GTRBE (09-24-2016)
Received 1,260 Likes
it sounds like the engine is running smooth to me... if I had to guess I'd say it's something on the outside of the engine or possibly in the clutch area
Not a rod or anything serious...take the belt off and you will find the issue. The engine is running too smooth for anything serious. Please let us know what you find. Good luck.
Pictures are too dark down in front area to get a good eyeball.
Definitely not rod knock...
if it was a pulley or something in the belt system i'm sure there would have been a squeak or something before it got this bad, to me it sounds like something in the valve train like a broke rocker or something getting knocked around
i had a ls with a bad valve at idle car was smooth idle but driving it there was a slight miss and the exhaust note was different
1/4 mile/AutoX
